Activity Forums Maxon Cinema 4D how to ‘bulge’ a group of fracture objects?
  • how to ‘bulge’ a group of fracture objects?
    Posted by Sergio Juyak on May 12, 2013 at 8:14 am
    I have a cube chopped up into fragments (blue image). I want the fragments to sort of bulge out as if something is erupting. I threw all my fragments into a fracture object and then experimented with the target effector and the ‘repel’ option. I get pretty close, but I can’t get the fragments to orient properly. I want the fragments to orient outward from the bulge, but can’t find any configuration of options in the target effector that will do this. The image of the orange cubes shows the sort of effect i’m going for.
    file: https://bit.ly/12qxRBL
    cube clones with target effector: https://bit.ly/19en1Bb
    Sergio Juyak replied 13 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 12, 2013 at 6:24 pm
    A genius named Yader has produced a tutorial that addresses this exact issue here: https://vimeo.com/34757109
    Because your object is oriented differently you would have to change it up in some respects.
    As Yader suggests in his text comment on the Vimeo page, you could also do this with dynamics, but you’d have to animate it to see the result in that case.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sergio Juyak
    May 14, 2013 at 1:21 am
    Well I guess if I really want this effect I know it’s possible. Thanks Adam. You guys always seem to have an answer for anything.
    btw – that guy *is* a genius.
