Activity › Forums › Adobe After Effects › how to build a disco floor like thata!
Posted by Tommaso Cicognani on June 6, 2009 at 1:21 pmHi all,
I’m working on building a disco floor like this (see link below)https://www.greentowel.com/images/qt/kennedy/GreenTowel_yourmama.mov
I tried using Cell Pattern effect with Colorama but I’m far from it!
How to make the floor color changing like that? any advice?
Any web store where could I buy the project?
TommasoSerge Hamad replied 17 years, 3 months ago 3 Members · 5 Replies -
Serge Hamad
June 6, 2009 at 2:47 pmHi,
You are using the wrong filter. Fractal Noise & Colorama would do the trick.
Create a solid, apply “Fractal Noise” to it.
– Set the Noise type to “Block”
– Set the Fractal Type to “Small Bumps”
– In the Sub Settings menu, set the “Sub Influence % to (0)
– Increase the scale property in the transform menu to taste.– Now add the “Colorama” effect and make sure that you add a black portion to your color wheel to give you the effect of light switching on & off.
– Animate the “Phase Shift” located in the Input Phase menu. Done!
Here is the project:
https://www.nyc-visual.com/disco_floor.zipSalut,
SergeInvigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
Tommaso Cicognani
June 6, 2009 at 4:20 pmThanks Serge for your help but how can I let it be more real?
I mean, for istance, the lights turn on and off not gradually (just on and off), how to make the floor seems more specular..
I tried adding some Glow effects and a little bit of CC light but it still appears too fake. -
Serge Hamad
June 6, 2009 at 9:19 pmHi Tommaso,
These light effects look way better when done with a 3D program butI just played with the project for a couple of min & think it may help you:
Basically, if you want your lights to switch on & off you need to disable the “Interpolate Palette” option for Colorama.
I added a grid using some masks on a black layer to better separate each light.
I hope this will bring you nearer.
Salut,
Giampietro Balia
June 7, 2009 at 11:28 ambut how do you create those bumps? You need something like Maya or 3dStudio Max?
Serge Hamad
June 8, 2009 at 2:58 amHi,
Almost any 3D program would create the floor.
Fortunately AE has two 3rd party plug-ins that can deform a layer in 3D:
FreeForm from Digieffects & 3D Warps from Zaxwerks.
Salut,
