Activity › Forums › Apple Final Cut Pro › How to blur or censor multiple faces or images
  • How to blur or censor multiple faces or images
    Posted by David Kirlew on February 14, 2014 at 1:38 am
    I have a client who requested me to blur multiple moving/shifting background images on one clip. I know can use censor and or shapes to create the keyframes for one image but I am having difficulty trying to do it with multiple image in the clip and shot. I did duplicate the clip to blur one of the images but if it is in the same shot can I blur both separate or will it use the same one blur effect? Will I need to duplicate the clip yet again to achieve the multiple blur effect?
    David Kirlew
    Reflection Concepts
    Dave Jenkins replied 12 years, 7 months ago 5 Members · 6 Replies
  • Andy Neil
    February 14, 2014 at 2:30 am
    Do you have Motion 5? Because you can create a blur effect that you publish to FCPX that will do the job without needing to duplicate anything.
    Andy
    https://www.timesavertutorials.com
  • Andy Mees
    February 14, 2014 at 2:59 am
    Lots of free plugins for FCP X that will allow you to add isolated blurs to an image.
    Alex Gollner offers a bunch here: https://blog.alex4d.com/2012/02/12/blurs-7-free-fcpx-effects/
    If you have FxFactory then you can try my own one here: https://andymees.wordpress.com/region-tool/
    These days I’m preferring to use Resolve Lite for this as it’s super fast and easy to track and blur multiple subjects.
    Cheers
    Andy
  • David Kirlew
    February 14, 2014 at 3:07 am
    I actually do have Motion 5 so I will give that a try.
    David Kirlew
    Reflection Concepts
  • Andy Neil
    February 14, 2014 at 3:24 am
    If you need a leg up here’s the basics of what you need.
    Create a new effects project.
    Clone the effect source layer.
    Apply a mask to the clone layer. Publish the controls.
    Apply a blur effect to the clone layer. Publish the controls.
    Then in FCPX, you just continue to apply the effect to your clip for each blur you need to make.
    Andy
  • Mark Morache
    February 14, 2014 at 6:11 am
    I’ve had good luck with Alex Gollner’s Circle Blur effect.
    I apply the effect and dial in the radius, amount and center. At the first frame of the clip, I create a keyframe for the center parameter, then I go forward 10 frames in the timeline (shift-right arrow) and move the center of the blur to the new position, and keep on doing that until I get to the end of the clip. I play the clip from the beginning and see how the blur is tracking, making some adjustments by adding keyframes where I need to.
    I then add another Circle Blur effect and do the same thing for the next blur I want to track.
    You can add as many as you need.
    I’d turn off the previous effects every time you add a new one, to keep the machine from slowing down, then turn them all back on when it’s time to render.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Dave Jenkins
    February 14, 2014 at 12:15 pm
    Slice X by Core Melt has a great tracker that will do all the key framing for you.
    Dajen Productions, Santa Barbara, CA
    Mac Pro 3.5MHz 6-Core Late 2013
    FCP X
