Activity Forums Apple Final Cut Pro Legacy How to black out a spot of a 2 second clip through FCP 7
  • How to black out a spot of a 2 second clip through FCP 7
    Posted by George Roberson on August 14, 2013 at 7:23 pm
    Hi, when we were shooting the movie (HD, digital) a gaffer’s tape shows up too obviously on a laptop. How to black this piece out (it was a black surface but the tape has slight different color, therefore is noticeable) on FCP7? Is it doable?
    Thanks!!!
    George
    George Roberson replied 12 years, 11 months ago 3 Members · 4 Replies
  • Joe Barta iv
    August 14, 2013 at 8:08 pm
    Try this, it works if there is not too much movement in the object you are fixing.
    Duplicate the clip on a track above it. Crop the clip to a small area right next to the gaffer’s tape. Make your cropped area about the same size, a little bigger is better. Then reposition the cropped clip over the tape. Some edge feathering will help too.
    Bars & Tone
    SALUTE!
  • Mark Suszko
    August 14, 2013 at 8:16 pm
    You could also try the “limit color” effect in the 3-way color corrector, as well as exporting a still to photoshop, cleaning it up with the clone brush, and then layering that back in with a soft-edge matte.
  • George Roberson
    August 16, 2013 at 4:56 pm
    Thanks so much everybody! Will give it a try…
  • George Roberson
    September 22, 2013 at 2:06 pm
    Hi Dave, how to use Motion to change that? Thanks so much!
