Activity Forums Adobe After Effects How to Bezier Path with no keyframes ?
  • How to Bezier Path with no keyframes ?
    Posted by Shai Benshoshan on January 7, 2019 at 9:38 am
    Using the powerful ‘ Create nulls from paths ‘ script, I am writing a script that reads the Path from an external XML file.
    The Path has no keyframes, but the points auto-created as linear :
    How can I convert the path to bezier by script? or expression?
    It can be done manually > select the path > alt+shift +click to convert the points to bezier :
    Can AE do it automatically?
    Shai
    Oleg Pirogov replied 7 years, 7 months ago 2 Members · 3 Replies
  • Oleg Pirogov
    January 7, 2019 at 10:30 am
    Since CC 18 you can directly access path nodes and their tangents in a manner like this:
    comp(“Comp”).layer(“Shape Layer”).content(“Shape”).content(“Path”).path.points()[i] = [666, 666]
    comp(“Comp”).layer(“Shape Layer”).content(“Shape”).content(“Path”).path.inTangents()[i] = [1, 0]
    comp(“Comp”).layer(“Shape Layer”).content(“Shape”).content(“Path”).path.outTangents()[i] = [0,1]
    Those “linear” nodes of yours are nodes with no tangent handles i.e. with In Tangent and Out Tangent both equal [0,0]. Changing those to something different than [0,0] will give you a Bezier curve.
    Hope this helps you one way or another.
  • Shai Benshoshan
    January 7, 2019 at 4:55 pm
    Thank you Oleg <:]
    I’ll try that ;
    So ill need to know what is the next point is to figure out the direction and value of those tangents.
    Since the path is created automatically
    tnx
    Shai
  • Oleg Pirogov
    February 2, 2019 at 3:30 pm
    I’ve written a script which does the thing for every selected property of shape type (i.e. select the shape path and run the script):
    //the script smooths (sets interpolation to Auto Bezier) selected shape properties
    //smooths a shape path
    function shapeSmoother(shape){
    //create dummy composition and a text layer in it
    var comp = app.project.items.addComp("Dummy", 100, 100, 1, 1, 1);
    var pos = comp.layers.addText().transform.position;
    //create key frames in null position for every shape vertex
    var newKey;
    for (var i=0; i
