Activity › Forums › Adobe After Effects › How to bend pictures to cylinder in 3D?
Posted by Hiostt on October 10, 2005 at 9:23 amI need to bend my pics to cylinder. How I do that?
Steve Roberts replied 20 years, 11 months ago 6 Members · 12 Replies -
Andrew Yoole
October 10, 2005 at 10:23 amCC Cylinder. This plugin is included in full versions (not academic) of AE 6.5.
Hiostt
October 10, 2005 at 3:32 pmConoa doesn’t work because i need to use own camera and not that in conoas effect. And also I can’t do half circles which I need.
Hiostt
October 10, 2005 at 4:13 pmI need that the hole layer goes into 3D. In conoa the object is only 3d inside the layer.
Chris Smith
October 10, 2005 at 4:19 pmWhy not do it in a 3D app? That’s what they’re made for. If not, maybe map it in Invig inside AE.
Chris Smith
https://www.sugarfilmproduction.com -
Steve Roberts
October 10, 2005 at 4:25 pmWelcome to After Effects. 🙂 That’s the way it works. Any 3D effect just creates a “movie” of a 3D effect, “playing” on one of AE’s flat layers.
If you want true 3D, use a true 3D app, as Chris suggests.
Steve
Hiostt
October 10, 2005 at 6:00 pmThere’s just one problem. It takes very long to learn how to use 3dsmax and I dont have too much time for this project 🙁
Steve Roberts
October 10, 2005 at 6:37 pmWell then, get Cinema4D from Maxon — it’s not that hard to learn (for a 3D app) and is good for motion graphics. Call their customer service to find out about their $99 version.
Other than that … we can’t redesign After Effects. 🙂
Steve
Chris Smith
October 10, 2005 at 6:44 pmBesides, you don’t need to learn the whole app. Just select the cylinder from the primitives options and map your graphic to it using cylindrical mapping.
Chris Smith
