Activity › Forums › Adobe After Effects › How to avoid fields when using DynamicLink
  • How to avoid fields when using DynamicLink
    Posted by __peter__ on October 5, 2008 at 1:46 pm
    Hi 🙂
    when importing AE Compositions via Dynamic Link into Premiere they alway use fields. For reasons of painless DVD MPEG encoding I use a Premiere interlaced preset. But my footage is 100% progressive. Which works fine.
    So I also do my AE Compositions without fields. Which of course also works fine when rendering them into a file and importing the results into my Premiere timeline.
    But for some compositions I would like to import the composition via Dynamic Link. And then that AE composition has fields. Clearly to see from that “smooth” look when something is moved or rotated like a text or graphic.
    By setting a check for deinterlacing in Premiere I clearly loose half the resolution, which is not good – of course 🙂
    So is there a way of interpreting the Dynamic Link compositions ?
    Or another solution ?
    Peter
    __peter__ replied 17 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
