How to automatically add file names into the picture?
Posted by Michal Bronec on August 28, 2012 at 3:01 pmI need to render a lot of clips I shot today and upload it on Vimeo. My client then look at the videos and give me some comments to particular shots. The shots are very similar, so I need a way how to automatically “mark” them. My client then tell me for example “shot MVI_3968.MOV needs to be reshot etc.” Is is it possible?
Steve Rhoden replied 14 years ago 5 Members · 9 Replies -
Steve Rhoden
August 28, 2012 at 4:06 pmWell, i hope i understand your question correctly. If you
want them named automatically on the timeline, you go to
View and select Active take information. Then if you want to
rename a particular clip’s active take name, you right click
on it, go to Take and then Rename active and make your change.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Mike Kujbida
August 28, 2012 at 4:59 pmIf Steve’s suggestion isn’t what you need, Excalibur has a tool called Quick Labels and Vegasaur has one called Text Generation Wizard.
https://www.jetdv.com/excalibur/home.php
Michal Bronec
August 28, 2012 at 6:54 pmNice tip, but this is not what I ment. I need the file names in the rendered video (like subtitles).
Aleksey Tarasov
August 28, 2012 at 7:06 pm -
Steve Rhoden
August 28, 2012 at 7:21 pmIf none of what is recommended to you above is not what you are
looking for, then what you want cannot be done that way.Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Mike Kujbida
August 28, 2012 at 7:30 pm[Michal Bronec] “Nice tip, but this is not what I ment. I need the file names in the rendered video (like subtitles).”
The two products I recommended will do what you want.
I’ve used Excalibur for this purpose and Aleksey is the developer of Vegasaur so I’m pretty sure he knows what it can do 🙂 -
Roger Bansemer
August 29, 2012 at 10:51 amAnother way you could do it is to put a time stamp on your video and just let him or her note the time where they want changes.
Roger Bansemer
Steve Rhoden
August 29, 2012 at 11:04 amStill, Using time stamp on your video as Roger mentioned
is a far easier method for both you and your clients.Steve Rhoden
(Cow Leader)
1-876-832-4956
