Activity › Forums › Adobe After Effects › How to automate mass twin edits
  • How to automate mass twin edits
    Posted by Wojciech Hołysz on July 5, 2016 at 7:10 pm
    I’m not neccessarily new to the forums, but since I lost my previous login info I guess this is my first post 🙂
    I’m looking for a way to automate product videos for e-commerce. Use case would be preparing repetitve footage of say 50 products ,e.g. wide, detail, mid and a close up shot for eachproduct. Each shot lasting a specific timespan (e.g. 1 second pre, 3 seconds roll, 1 second rest) and beeing prepared according to custom specification.
    Having the 50 products shot 4 ways each, files downloaded into separate folders (or into one), I would like to run a script that would take the footage, insert (replace) it into a previously prepared edit template (in a Premiere Pro or After Effects project) and render it with prespecified settings (format, resolution, etc.). Even more preferably I could load a project, point a folder, replace all footage with one click – check for adjustments and queue render.
    Is that possible with AE scripts or in any other way you guys know of? The point of this would be mass production of very simple product videos.
    Walter Soyka replied 10 years, 2 months ago 2 Members · 1 Reply
  • Walter Soyka
    July 6, 2016 at 2:07 pm
    You could probably do this with CompsFromSpreadsheet, if you import all the footage items into your project, build a template, and build a spreadsheet to control the creation of the comps:
    https://aescripts.com/compsfromspreadsheet/
    To automate it as simply as you describe, you’d need to write (or hire someone to write) a custom script.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
