Activity Forums Adobe After Effects How to Auto-Orient a 3D object on a 3D path on only 2 axes?
  • How to Auto-Orient a 3D object on a 3D path on only 2 axes?
    Posted by Rafael Irimie on October 28, 2024 at 12:17 am
    Hi everyone, I’m new to Ae and I’m trying to experiment/explore new techniques.
    I’m animating a paper plane along a 3D path. When I enable auto orient it auto orients it on all axes X, Y, Z. This is almost perfect, except I want to be able to control the banking of the plane, in my case the Y axis, independently. Is there a plug-in, script, expression, anything that could help me fix this?
    Rafael Irimie replied 1 year, 10 months ago 2 Members · 2 Replies
  • John Cuevas
    October 30, 2024 at 1:32 pm
    After auto-orienting to the path, you can still open up your rotation property and keyframes orientation or the XYZ rotation.
  • Rafael Irimie
    October 31, 2024 at 9:47 pm
    Hi John, thank you for replying to this.
    The problem with the approach you suggested would be that if I enable auto-orient I’d need to then manually keyframe the rotation of each frame of my animation to counteract the rotation of auto-orient on that axis. If I then change my mind on timing or spacing for the position values I’d need to keyframe each frame once again. Whereas if I were able to lock the axis I want to control manually, I could just keyframe the key points and then interpolate.
    Let me know if you have a solution for this please.
