Activity Forums Creative Community Conversations How to assign tracks and audio outputs on fcpx (to write back to xddisc)
  • How to assign tracks and audio outputs on fcpx (to write back to xddisc)
    Posted by Jurriaan Van der kamp on October 13, 2011 at 2:06 pm
    How export a project (the former sequence) directly back to a sony 530 xdcam? In FCP7 in order to
    export a sequence to an xddisc i needed to change the audio sequence setting from dual mono to 8 outputs dual mono. After this step i had to ajust the overal audio level with -6 db. Now i could also chose that for example your general noice is on track one and your voice over is on track 2. How can i accomplice this with fcpx?
    Jurriaan Van der kamp replied 14 years, 10 months ago 3 Members · 4 Replies
  • Jurriaan Van der kamp
    October 14, 2011 at 1:01 pm
    hallo,
    Does nobody no this?! is this a pro forum?
  • John-michael Seng-wheeler
    October 17, 2011 at 4:12 pm
    More like, wrong forum. Try posting again in the FCPX Techniques forum.
    https://forums.creativecow.net/fcpxtechnique
    JM
  • Christian Schumacher
    October 17, 2011 at 4:59 pm
    [jurriaan van der kamp] “Does nobody no this?! is this a pro forum?”
    No, you’ve got it backwards.
    This forum is about figuring out if the software itself is. Literally.
    October 17, 2011 at 9:37 pm
    thats deep Christian!
    So i will try my luck at the techniques forum. So this forum is strictly opinion..?
