Activity Forums Adobe After Effects How to apply not moving mask to multiple layers?
  • How to apply not moving mask to multiple layers?
    Posted by Eri Kossus on May 5, 2012 at 8:14 am
    I am making clips with moving image on transparent background. Images are RotoTooled before and rendered RGB+Alpha.
    My goal is to cut away additional parts of remaining image in several clips at precise position. So far I have been copying the created mask directly to the clip. But I run into problems when I need to adjust the clips size. The mask will change the size as well but this would mess up everything.
    I tried to put the mask on Shapes or Adjustment layer and parent it to the clip, but the mask will not cover anything. Obviously I can not mask with Solid due to transparency.
    I am sure it is very basic and I am missing something obvious.
    Eri Kossus replied 14 years, 4 months ago 62,627 Members · 1 Reply
