Activity Forums Maxon Cinema 4D How to animate the splitting of a blood vessel as if its burst
  • How to animate the splitting of a blood vessel as if its burst
    Posted by Craig Ricker on December 10, 2012 at 11:35 pm
    Hey guys,
    I’m not very good with cinema 4d, just been teaching myself with no real instruction.
    What i’m trying to make at the moment, is a blood vessel bursting and letting blood cells leak out.
    Got the blood cells part working fine, just trying to figure out how to make a blood vessel split realistically.
    I thought if I could make 4 individual groups of polygons bend outwards making it look like its burst. I know how to disconnect polygons or split them from the main object, but how do I attach just one edge again to the main body and then make it bend only on the disconnected part?
    Any help would be greatly appreciated
    Rasmus Gerner replied 13 years, 9 months ago 2 Members · 1 Reply
  • Rasmus Gerner
    December 11, 2012 at 10:10 am
    You can connect objects weld point using weldtool (hotkey M+Q). What you want is to hand animate each point. It will be easier to use morph tag if you have it.
    You can also use cloth or a plugin like xbreaker depending on the structure of the cell.
    Hoped it helped and have fun
