Activity Forums Adobe After Effects Expressions How to adjust the duration using marker or slider?
  • How to adjust the duration using marker or slider?
    Posted by Doni Donovan on July 28, 2016 at 7:33 am
    i just wondering if there is a way to set the duration using expressions on time remapping and can be controlled by marker of slider?
    for example i have “animation in” in a composition and i dont want to create a “animation out” manually, i just want to reverse the “animation in” then use it as outro, but i want the outro start in specific time and controlled by marker or slider.
    The simple is i want to adjust the freeze area duration before the outro coming, instead of duplicate the comp and use time-reverse
    *sorry my english is not good, i am from indonesia
    Doni Donovan replied 10 years, 1 month ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    July 28, 2016 at 8:09 am
    Isn’t it easier to select the two time remap keyframes and drag them where you want?
  • Doni Donovan
    July 28, 2016 at 8:17 am
    Thanks for reply dude,
    this project is a template so it could be better to make it easier to change the duration, for a beginner user.
