Activity Forums Adobe After Effects How to add/project tattoo to moving/rotating head using camera tracker – AE CS6
  • How to add/project tattoo to moving/rotating head using camera tracker – AE CS6
    Posted by Richard Decosta on January 30, 2013 at 10:34 pm
    Source: A green-screen plate of a medium or close shot of a person talking. They have several tracking dots on their face.
    Goal: To add a tattoo to the person’s face, that moves with them as they talk, move around, rotate head, etc.
    Solution: Anyone?
    I can do a 3d camera motion track a surface easily enough, but how would I add a tracked camera that essentially acts like the person’s face is a surface, follows it around, projecting an image.
    Cheers!
    Todd Kopriva replied 13 years, 7 months ago 4 Members · 5 Replies
  • Richard Decosta
    January 31, 2013 at 12:32 am
    Yes, still in the planning stage. The trick is, the face tattoos need to animate as the people talk and move (they change based on a person’s mood/thoughts), something like what Rorschach’s mask does in the Watchman movie.
  • Vishesh Arora
    January 31, 2013 at 9:34 am
    Richard
    A powerful tracking application like Mocha AE(Comes with AE CS% and above) will help.
    See the Similar Tutorial by Eran Stern :
    https://vimeo.com/17651556
    I would suggest you to learn Mocha first :
    Learn Mocha AE
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Richard Decosta
    January 31, 2013 at 1:30 pm
    Looks interesting, thank you!
  • Mackenzie Criswell
    January 31, 2013 at 9:09 pm
    The way that I would do it is to closely model they area of the head where you need the tatto to be. Then put a material on the model to match it. Go back into after effects and put the model bakc on using the tracked footage then change the blending mode to something like overlay, and possibly do something with some inner shadows.
    To get the model you would need to have the model annimated in a 3D program and to do this you would need to first track the head with the 3D camera tracker then export the scene to the 3D program. To do this you would need to gogole the AE 2 3D script.
    If this seems complicated you might try just puling a 2D track, compositing the tatto agian with maybe an overlay blending mode. Then use some of the different ditortion effects to make it look like it is stuck when the head turns.
    Also there are a couple of good tutorials by Andrew Kramer that might be a little bit helpful:
    https://www.videocopilot.net/tutorials/skin_displacement/
    https://www.videocopilot.net/tutorials/the_healer/
    Mackenzie Criswell
    Filmmaker
  • Todd Kopriva
    February 1, 2013 at 6:24 am
    Dave Torno’s face replacement tutorials will give you a good start:
    https://blogs.adobe.com/aftereffects/2009/04/face-replacement-with-mocha-fr.html
    After Effects team blog
