Activity Forums Adobe After Effects Expressions How to add time expression but start from the current value
  • Dan Ebberts
    September 11, 2015 at 6:08 am
    Like this:
    value + time*1
    (although you don’t need the *1)
    Dan
  • Doni Donovan
    September 11, 2015 at 7:01 am
    Aw crud, I just realized that the “time” there refers to the current duration multiplied by a number.
    thanks Dan you are the best 😀
    i have another problem how to move object continuously using X Position with time expression..
    i cant use the same method because my object is not start from zero keyframe
