Activity › Forums › Adobe Encore DVD › How to add the click’ sound to a button and to set up Backgorund Music
  • How to add the click’ sound to a button and to set up Backgorund Music
    Posted by Art Alvarez on February 15, 2010 at 10:17 pm
    Hi:
    This might be to easy but I do not find the way of doing it.
    I have tried to set up on the Button>Properties>Transition’ Tab (Assets) and attempting to use the pick whip to the wav file on my projetc’ section but does not work. Is it possible to do this ?
    By the other hand, I am attemting to set background music for my entire presentation but neither of the two methods I have tried generated the desire result:
    . I added a Sound track to my timeline (with chapters on it), but it plays fine until I select the Chapter then the music stops and the chapter plays but w/o music. Once I get back to the Menu/Sub-Menu the music resumes.
    . I can set it up on my Menu and Sub-Menus, but the music stops when I select and play the chapter.
    Is there any way to set up backroung music regardless of the point of where you are at (Menu/Sub-Menus/Chapters)
    Thanks in advance for your help,
    Art Alvarez replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
