How to add the click’ sound to a button and Backgorund Music
Hi:
This might be to easy but I do not find the way of doing it.
I have tried to set it up on Button>Properties>Transition’ Tab (Assets) and attempting to use the pick whip to the wav file on my projetc’ section but does not work. Is it possible to do this ?
By the other hand, I am attemting to set background music for my presentation but neither of the two methods generates de desire result:
. I added a Sound track to my timeline (with chapters on it), but it plays fine until I select the Chapter then the music stops.
. I can set it up on my Menu and Sub-Menus, but the music stops.Is there any way to set up backroung music regardless to the point of where you are on the presentation.
Thanks in advance for your help,
