Activity Forums Adobe After Effects How to add textures to TEXT in AE 6?
  • How to add textures to TEXT in AE 6?
    Posted by Richard Garabedain on July 8, 2013 at 8:26 pm
    I had thought there was a way to add materials to text in AE 6. I see material options under the text, but i do not see a place to actually add the material. I feel stupid…
    Isaac Borjas replied 13 years, 1 month ago 3 Members · 2 Replies
  • Todd Kopriva
    July 9, 2013 at 12:03 am
    If you’re trying to add an image layer as a texture for the face of a 3D object, you can’t do that.
    See these resources for what the material options properties are for:
    https://blogs.adobe.com/aftereffects/2012/05/free-3d-material-options-project-and-tutorials-for-after-effects-cs6.html
    After Effects team blog
  • Isaac Borjas
    July 9, 2013 at 6:09 pm
    Or if you want your Text to look 3D’ish with the Texture you Want use the ” Shatter Effect ” on the Texture Layer you want to use and change the follow settings :
    Under Shape
    Patter = Custom;
    Custom Shatter Map = Your Text Layer;
    Under Both Force (1 & 2)
    Force = 0;
    Radius = 0;
    Strenght = 0;
    and that pretty much it, you can play with the ” Extrusion Path ” for more 3D look there is some limitations to this so keep that on mind.
