Activity › Forums › Zaxwerks › How to add moe Fonts to 3D Invigorator text?
  • How to add moe Fonts to 3D Invigorator text?
    Posted by Lord Scales on June 4, 2007 at 1:11 am
    Hi there!
    I like creating 3D Text in Invigorator, but I have a font called Carta, available in the text tool of AFX, but not in the Invigorator’s.
    So, how can I add more fonts to text in Invigorator? Thanks a lot!
    Jon Okerstrom replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    June 4, 2007 at 11:37 pm
    Hi Lord Scales,
    If the fon’t available in your sytem, you should be able to see it. If you have an issue with a particular font, you may want to send it to tech support so they can take a look.
    The short-term solution, of course, is to convert the text to outlines in Illustrator. It’ll behave the same as any other object then.
    Jon
