Activity › Forums › Adobe Premiere Pro › How to add an Multi-cam Nested sequence to another project.
  • How to add an Multi-cam Nested sequence to another project.
    Posted by Barry R. ervin on April 23, 2007 at 3:02 am
    Hello All,
    I would like to know how to add a multi-cam nested sequence to an exsisting project in APPro 2.0.I have two projects,1st:T&L Wedd Main,
    2nd: T&L Wedd multi-cam.The T&L Wedd Main now has my opening,pre stills,pre wedding bride and groom clips.Now I would like to add the multi-cam and nested seqences to it.In AP 6.5 all you had to do was file,import,(file,folder or project)then it would ask you were you wanted to position it,(at the time line,begining or end.the reason I did’nt build the sequence into the main this was my first time doing it and I did not want to mess up the main project.Hope you all can understand what I am trying to do.
    Thank You,
    VideoBarry
    Blast1 replied 19 years, 5 months ago 2 Members · 1 Reply
  • Blast1
    April 23, 2007 at 6:53 pm
    [Videobarry] “Now I would like to add the multi-cam and nested seqences to it.In AP 6.5”
    The multi-cam and nested sequences are not backwards compatible from Ppro to Prem 6.5 unless exported to Movie->DV AVI and then imported as a clip.
