Activity Forums Adobe After Effects How to add a 3D text label to VideoCopilot Orb
  • How to add a 3D text label to VideoCopilot Orb
    Posted by Thomas Hannen on November 4, 2022 at 10:34 am
    I’m using the Video Copilot Orb plugin to build a 3D earth model, using a camera to track round the planet, and additional Orb layers to add clouds etc.
    What’s the best / right way to add text labels that will precisely follow the surface of the orb?
    E.g: A label that says “New York” that will correctly track the position as the camera moves, or as I rotate the orb?
    At the moment I’m making doing this:
    • Creating a 3D text layer
    • Positioning it at the distance of the radius of the Orb plugin’s sphere
    • Auto-orienting the text layer to my camera
    • Parenting the text layer to a 3D null at the centre of the sphere, and using expressions to parent the rotation of the 3D null to the rotation of the Orb sphere.
    • Rotating the 3D null to move the text around the globe.
    This is a bit fiddly, and not working well if I need to zoom in to close to the globe.
    I tried making a new texture on a second Orb layer and applying 2D text to that surface, but it distorts badly due to the projection of the 2D texture on a 3D space.
    Any tips appreciated.
    I have read this post, but it even the central point on my text layer isn’t maintaining the correct position on the globe.
    What’s the right way to get a good lock on the globe?
    Thomas Hannen replied 3 years, 10 months ago 2 Members · 2 Replies
  • Graham Quince
    November 5, 2022 at 1:01 pm
    It might not be the “best / right” way to add labels, but I made a tutorial a couple of years back where I use 3D null objects, parented in such a way that you can set longitude and latitude coordinates and then link a 3D text layer:
    https://youtu.be/tVVKNs56H4c
  • Thomas Hannen
    November 8, 2022 at 9:26 am
    Very useful – many thanks
