Activity Forums Adobe After Effects How to get 3D stroke to anchor to points on a globe?
  • How to get 3D stroke to anchor to points on a globe?
    Posted by Markus Stone on May 21, 2020 at 10:03 am
    Hi all, I’m trying to do an animation of a rotating globe (using video copilot’s Orb plugin) with some 3D stroke (trapcode) to connect a few cities together.
    The problem is that I don’t know how to make the bottom of the stroke end on the surface of the sphere.
    Anyone know how to do this?
    Cheers
    Markus
    Markus Stone replied 5 years, 12 months ago 1 Member · 1 Reply
  • Markus Stone
    May 22, 2020 at 6:13 am
    I managed to figure out a solution, so I thought I’d update the post in case anyone else is looking to do something similar.
    Take the layer with the 3D stroke and set it’s Z-depth to = the radius of the sphere in the Orb plugin.
    That gets you close.
    Make the masks in the stroke layer, with one end always starting on the centre of the layer so that when you apply transforms in the plugin at least one point is in the right place.
    Use transforms within 3D stroke to find the correct orientation for your paths. You can adjust the paths themselves, but you’ll only really be able to control the length of the line that way.
    Using a camera orbit to check the contact on the limb of the sphere works well too.
    Thats it.
    Hope it helps someone else.
    Markus
