Activity › Forums › Apple Motion › how to achieve….tumbling icons
  • how to achieve….tumbling icons
    Posted by Adam Taylor on October 30, 2006 at 9:09 pm
    I’m having trouble trying to create a tumbling icon effect. I have done a small version over a few seconds, but i need the finished result to last for several minutes, and not run to hundreds of layers.
    essentially I have an icon of a man which rotates around its centre, and falls from above the screen to below it. This is then repeated so the icons cascade downward with four or five icons visible at any one time.
    Any suggestions how to achieve this effect?
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Winston A. cely replied 19 years, 11 months ago 3 Members · 3 Replies
  • Peter Wiggins
    October 30, 2006 at 11:12 pm
    Have you tried making your man into an emitter?
    Peter
    Free Motion Templates
    peterwiggins.com
  • Adam Taylor
    October 31, 2006 at 8:58 am
    yes, but i haven’t been able to figure out how to create the particles at a constant pace and in a straight line.
    They all seem to float around aimlessly – i want mine to start at a definite point, travel a defined distance along a straight path at a constant speed.
    As i mentioned, i have managed this with a single icon, which i then duplicated and offset the start frame/ This works fine for short periods but for several minutes would take hours to set up.
    Adam
    Editor/Mixer
    Oldham, UK
  • Winston A. cely
    November 2, 2006 at 4:10 am
    I’d go back to the particles and maybe add the gravity simulation to it. Try this site out, as they’ve got great demos, and they often get me going in the right direction: https://www.motionsmarts.com/
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
