Activity Forums Adobe Premiere Pro How Split Stereo Audio To Two Mono Tracks
  • How Split Stereo Audio To Two Mono Tracks
    Posted by Tom Salyer on March 28, 2012 at 5:48 pm
    I’ve recorded a lav mic to the left channel of my audio file, and a boom to the right.
    Is there a way to separate this stereo file into two independent mono files that I can work with on a timeline?
    I can duplicate the stereo two-mic track, apply the Fill Right effect to one copy, and the Fill Left Effect, to the other, and I end up with two stereo tracks, one with two L sides, the other with two R sides. But this seems awkward.
    And/but, I want to work with mono dialog tracks, correct?
    I’ve tried creating a sequence with two mono tracks, no stereo audio tracks, but then the sequence will only let me bring in the two-mic track as a stereo track.
    How do I split them ?
    Thanks. Tom
    Tom Salyer replied 14 years, 6 months ago 1 Member · 1 Reply
  • Tom Salyer
    March 29, 2012 at 10:51 pm
    I believe I’ve found out two methods to answer my question … corrections gladly accepted :
    1) Setup a new project > Premier Pro > Preferences (on a Mac)> Audio
    in the Source Channel Mapping area/ Audio Channels, choose Mono from the Default Track Format drop down menu > OK
    Now when ever you pull a video clip with stereo audio track, or a stereo audio track, onto the timeline, the
    audio tracks automatically show up as two mono tracks on the timeline.
    2) Select a video with stereo audio file or a stereo audio file in the Project Panel > Clip > Audio Options > Breakout To Mono
    Now the video/audio files shows up with xyz.mov Left & xyz.mov Right underneath the original file in the Project Panel
    Pull two broken apart mono tracks onto timeline.
    Pages 215, 216 Premier Pro user manual CS 5.5
