Activity › Forums › Adobe Premiere Pro › How much may I scale my footage for broadcast?
  • How much may I scale my footage for broadcast?
    Posted by Samuel Enblom on September 11, 2013 at 2:14 pm
    Hi fellow cows!
    As mentioned in the title, how much is considered OK to scale in post for broadcast TV?
    Im currently editing a documentary that will be aired on a Swedish TV-channel next year. Most of the footage is recored with a Canon 5D mark 3 or a 7D (1080, 25p). I’ve always told my fellow editors that its OK as long as you dont cross 120. However, in the last shoot one of the photographers did a really bad frame on a shot we really want to use, therefore my question.
    This TV-channel have a HD-channel aswell, so its highly possible that it will actually be broadcasted in 1080.
    I appreciate your help!
    Samuel Enblom replied 12 years, 12 months ago 9 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    September 11, 2013 at 5:03 pm
    20% is pushing the upper limit. Anything more will bring out the compression noise to a very viewable range.
    Shane
    Little Frog Post
  • Kevin Reiner
    September 11, 2013 at 5:12 pm
    Over 120 is pushing it, but it depends on the shot. There are some plugins that are supposed to do a little better job at scaling up footage.
    Adding noise reduction might help, but it will also introduce some more fuzziness.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    Nvidia Quadro 4000
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.8.4
    FCP 7
    Premiere CC
    After Effects CC
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Chris Harlan
    September 11, 2013 at 6:31 pm
    I never like to push it above 20%, and even then, I’m more comfortable with 10 or 15%. That said, I have–at times–pushed it much further.
    The biggest question is: Can you get away with it. That’s up to your eyes; none of us can tell you here. Each shot is its own beast.
  • Jeff Pulera
    September 12, 2013 at 8:17 pm
    Hi Samuel,
    What’s worked really well for me is to edit 1080p footage in a 720p sequence, then I have plenty of room to zoom without any quality loss. However, if you need a 1080p master, then this option is no good.
    Jeff Pulera
    Safe Harbor Computers
  • Rikk Desgres
    September 12, 2013 at 9:25 pm
    Depends how much the director tells you 😉 I’ve done some insane scaling for national broadcast.
  • Daniel Peterson
    September 13, 2013 at 12:30 pm
    Soon you may be able to try using this new effect in After Effects for upscaling – Detail-preserving Upscale
    https://tv.adobe.com/watch/adobe-at-ibc-2013/after-effects-cc-detailpreserving-upscale
    Filmmaker | Motion Graphic Artist
    http://www.saltmedia.net
    http://www.TheDigitalSlice.com (beta)
    What’s your weapon of choice… FCP7, FCPX, Premiere, Avid, Smoke, Edius, Vegas? Jump over and help gather some data.
  • Gary Alan
    September 18, 2013 at 2:39 am
    I have AE CC with the latest updates. Where is Detail-preserving Upscale ? I don’t see it listed under Effects.
    Gary
  • Daniel Peterson
    September 18, 2013 at 2:41 am
    It’s coming in the next update, next month… if you can wait that long…
    https://blogs.adobe.com/aftereffects/2013/09/after-effects-cc-12-1-whats-new-and-changed.html
  • Samuel Enblom
    September 18, 2013 at 7:54 am
    Thank you so much for all of your replies. This will be aired 2014 but deadline is about december 1st so we have time to tried the scaling with next months update.
    As I suspected, I should probably “take a bite in the sour apple” and realize that I shouldn’t go beyond 20%. What also worries me is that 5D and 7D is already highly compressed.
    But once again, thank you for all of your replies!
  • Paddy Uglow
    September 18, 2013 at 9:50 am
    Oooh, that After Effects upscale looks nice. Is there a similar (free or cheaper) tool that’ll do the same thing for those of us on a low budget?
    On this subject, though slightly off-topic, if I’d converted all my avchd footage to AIC or ProRes before putting it on the timeline (eg in Premiere Pro), would it scale better, having come from a less compressed source?
    Paddy, CreativeMedia.org.uk
