Activity Forums Adobe After Effects How many Drives should i use for best AE CS6 Performance ?
  • How many Drives should i use for best AE CS6 Performance ?
    Posted by Mazzaro Stefano on January 6, 2016 at 5:02 pm
    Hi Folks,
    Well, I am setting a new storage configuration to improve Global Performance in AE CS6.
    From what I understand, the best disk configuration would be :
    1 SSD for Operating System + After Effect CS6
    1 SSD for Footage Files (active project)
    1 SSD for Disk Cache
    1 SSD for Rendered Output
    So we have here 4 SSD’s. I will probably use a 5th disk (HDD) to store finished Projects.
    Am I right ?
    Thanks for help
    Stef
    Tero Ahlfors replied 10 years, 8 months ago 3 Members · 4 Replies
  • Mazzaro Stefano
    January 6, 2016 at 7:25 pm
    Thank you Dave.
    But from what I learned, SSD’s are recommended for faster memory access and fast Read/Write speed.
    I went to this conclusion : in order to avoid the drives to read and write simultaneously. Wouldn’t this configuration reduce render time ?
    Also, I’m not sure what do you mean by using ” a nice external array ” ?
    Sorry English is not my native language.
    I appreciate your help
    Stef
  • John Cuevas
    January 7, 2016 at 4:00 pm
    I built a 4 SSD configuration, similar to what you are building. On some projects extremely complicated projects, I do get a bump in rendering times compared to our other systems in the office. If I could go back though, I probably would have done 1-2 SSD drives and one large HDD for source and rendering and then invested the difference on my CPU’s. Just my 2 cents.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mazzaro Stefano
    January 7, 2016 at 4:39 pm
    I am surprised not to find any benchmark on the internet that shows the performance of a 1 disk configuration vs multi-disk configuration ..
    While Adobe recommends the exclusive use of 1 SSD for cache disk, others users advise 1 disk only for render, 1 disk only for sources, etc..
    My questions are :
    – Will preview and render really improve with multi-disk config ? (so get better workflow)
    – What would be this improvement 5% 10% 15% … ?
    Thank you Johnny for sharing your experience, it really helps me !
    If any others have some clue on this, please feel free to share.
    Stef
  • Tero Ahlfors
    January 8, 2016 at 5:02 am
    You will get redundancy and speed with a RAID. If you have a RAID 5 setup you can lose one drive and still have all the data. If one of your SSD’s malfunctions that’s it.
