Activity › Forums › Apple Final Cut Pro Legacy › How many Drive can I Daisy chain?
  • How many Drive can I Daisy chain?
    Posted by Blake Porter on August 21, 2008 at 1:58 am
    Does anyone know how many external firewire drives I can safely chain together? I have 8 right now, but could easily double..
    Mac G5
    Final Cut Pro 6.0.4
    (all for Video editing)
    Ben Holmes replied 18 years, 1 month ago 4 Members · 3 Replies
  • Shane Ross
    August 21, 2008 at 2:09 am
    I’d start looking at alternative solutions now if I were you. YOu can get 8 bay SATA RAIDS that are much faster than FW, and more reliable.
    Shane
  • Jeff Carpenter
    August 21, 2008 at 4:26 am
    I believe the limit is 16. After that you could buy another firewire PCI card and more there.
    That being said, I agree with Shane. You should probably be looking in eSATA units with an eSATA card to connect to it.
  • Ben Holmes
    August 21, 2008 at 8:53 am
    It’s just not sensible to add more devices to the same bus – at a certain point you will just slow down access to the drives. Invest in something safer (RAID 5 or similar) and cheaper (without multiple enclosures) like an eSata array. I use 2 G-Tech G-Speed ES as one 8 drive RAID 5 array. 4 TB, and fast enough for uncompressed 2K…
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
