Activity › Forums › Adobe Premiere Pro › how many clips?-multicam
  • how many clips?-multicam
    Posted by Tielman Dewaele on April 21, 2012 at 12:08 pm
    hey just shot a clip with 6 different angles.
    When using the multicam edit, i can only see 4 angles.
    Can premiere handle more than 4 clips? How can i see all the clips?
    thx
    MacPro Intel Quad Core 17G Ram
    MacBookPro Intel Duo Core 2G Ram
    Cs5 Production Premium
    Cinema4D 11.5
    Final Cut Studio 2
    Alex Udell replied 14 years, 5 months ago 2 Members · 3 Replies
  • Tielman Dewaele
    using cs5.5
    Cinema4D 11.5
    Final Cut Studio 2
  • Alex Udell
    April 21, 2012 at 3:28 pm
    using 5.5 the limit is 4
    using CS6 (when available) = no limit (subject to system capability to play back)
    Alex
  • Alex Udell
    April 21, 2012 at 3:59 pm
    In a nut shell…
    creating your own multicam by
    stacking scaled down, synced clips on multiple tracks and then splice cutting upward to the top track can be done pretty easily.
    1) stack 6 cams on tracks 1 thru 6 scaled and repo’d so as to create a multicam grid
    3) us the titler to add text overlays to indicate which PIP corresponds to which video track, and cut this on to track 7
    2) export that sequence as a clip and cut it onto track 7 (replacing the the title overlay)
    3) reset the scale and position of the PIPS on tracks 1-6 (this is important so that when you bring the splice up to track 8 it is full screen and completely covers the multicamera grid clip on track 7)
    4) now you can splice and cut from tracks 1-6 UP to track 8. just mute the track 8 temporarily to reveal track 7 if you need to see the multicam ref clip on see what all the cameras are doing.
    I’ve used this on a number of multi-cam, multi-take projects and it works pretty easily.
    hope that helps…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
