How fast should my LTO tape access be?
A lot of the recent posts have been relating to performance issues with LTO tape – whether using BRU, LTFS-based, or other archival / backup solutions. In a couple of off-list discussions, it dawned on me that while BRU is generally faster than most LTFS implementations, the numbers being seen by some LTFS users were way off the mark – even when using LTFS with Finder or File Explorer. I realized when replying to one discussion on the Cow this past weekend that we’ve not been looking at the performance of the source disks with relation to the slow tape write speeds.
The big point to keep in mind is that if your source disk can’t deliver at least 180MB/sec or better continuous read performance, there’s no what that ANY tape software will be able to drive your LTO-6 tape drive in streaming mode.
You should examine your source disk performance with a tool like the BlackMagic Disk Speed Test or the AJA System Test software.
For LTO-5, your source disk must be able to maintain a sustained read rate of 150MB/sec. For LTO-6, your source disk must be able to maintain a sustained read rate of 190MB/sec to 200MB/sec. Anything less and your tape drive will “shoe shine” or suffer from buffer underruns while writing. This shoe shining will slow the process further since the tape drive must reposition the tape to start writing again after the buffer catches up.
As examples – a USB-3 striped spinning disk array of at least 3 , 7200RPM disks or a single high end SSD will be capable of driving a single LTO-5 or LTO-6 drive. Most Thunderbolt solutions will be fast enough so long as they are either using 3 or more 7200RPM disks or SSD drives. On the other hand, the standard disk in a Mac Mini will not even drive an older LTO-4 drive (80MB/sec).
Therefore, before you consider blaming the tape drive or the archival software, start by checking your source disks’ performance with one of the tools mentioned above.
Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.tolisgroup.com
BRU … because it’s the RESTORE that matters!
