Activity Forums Apple Final Cut Pro Legacy how does rendering and Audio-Video Settings in FCP impact exported files
  • how does rendering and Audio-Video Settings in FCP impact exported files
    Posted by Kari on October 31, 2006 at 10:33 pm
    Hello. I was just wondering how rendering and Audio-Video Settings in FCP impacted exported files. I am asking this because a client when trying to dump to tape was having artifacts in his output. I made sure the av settings, seq settings, and material were the same codec and all went well—artifacts gone. This makes complete sense.
    The client was having the same artifacts appear in his MPEG2s he generated through compressor to burn to dvds. I haven’t jumped in to trouble shoot this yet, but I was wondering how sequence settings and AV settings impact exports? If codecs of material and sequence do not match will the system render so they match and then export? Do sequence settings trump clip’s codecs on export? I noticed a sequence becomes unrendered when exporting.
    Just trying to understand a little more about how FCP thinks.
    Thanks in advance for any feedback.
    Best
    Kari
    David Bogie replied 19 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    November 1, 2006 at 12:51 am
    It’s a very complex situation and normally answered easily by the cheeky copout: “Your client will need to perform dozens of hours worth of experimentation.” Wish it was easier but that’s about it.
    So much depends on how the export is managed. You can go directly via Compressor and force new render media to be created or you can create a self-contained movie file and bring that into Compressor. You can use better compression systems. If you open up the controls for MPEG2, you will see there are many possible ways to mess it up.
    Sorry to be evasive but if MPEG2 is critical, your client will, umm, have to do lots of experimentation. There are dozens of excellent compression books on the market.
    bogiesan
