Activity › Forums › Apple Final Cut Pro Legacy › how does one work with ProRes
  • how does one work with ProRes
    Posted by Mahesh Dood on August 19, 2009 at 2:43 pm
    hi
    1) inorder to capture HD footage directly into your comp using the ProRes codec do i need to have hardware support? which is the best harware device?
    2)if have already captured HD footage in the HD format, but i want to work on the timeline with a ProRes format, do i have to export all my footage using the ProRes codec, and then import it back to my project? or how does one work with ProRes without actually having captured in that format?
    thanks
    mahesh
    Michael Craven replied 17 years, 1 month ago 4 Members · 5 Replies
  • Russell Lasson
    August 19, 2009 at 3:05 pm
    What formats are you using?
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Mahesh Dood
    August 19, 2009 at 3:08 pm
    i am using HD 1920x1080i 50i
  • Chris Poisson
    August 19, 2009 at 3:41 pm
    What format are you capturing from? To get ProRes from HDV you can do it over FireWire.
    https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    Have a wonderful day.
  • Russell Lasson
    August 19, 2009 at 4:15 pm
    As Chris said, what camera are you capturing from?
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Michael Craven
    August 19, 2009 at 6:06 pm
    1) Kona, BlackMagic and Matrox all make devices that will capture with ProRes. HDV footage can be captured to ProRes via Firewire.
    2)If you have footage previously captured with another codec just drop it into a ProRes timeline and edit away.
