Activity › Forums › Adobe Premiere Pro › How does one mute and solo audio in the Source Monitor?
  • How does one mute and solo audio in the Source Monitor?
    Posted by Paul Dougherty on December 16, 2014 at 4:50 pm
    How does one mute and solo audio in the Source Monitor? That is to audition a discreet track on the Source / playback side, that is not yet in the Timeline.
    Paul
    Paul Dougherty replied 11 years, 9 months ago 2 Members · 3 Replies
  • Paul Dougherty
    December 16, 2014 at 5:03 pm
    I’m working off a 8 ch split track master and would also like to make a sub-clip that is just one trk derived from this Multi-trk Qt master
    Paul
  • Tero Ahlfors
    December 16, 2014 at 5:26 pm
    [Paul Dougherty] “How does one mute and solo audio in the Source Monitor?”
    When you have the source window selected the audio mixer tab should only work for the clip currently in the source window.
  • Paul Dougherty
    December 16, 2014 at 6:24 pm
    Thanks, I thought that but the mixer seems stuck reflecting the solo situation on the Pgm side. I got it to work by tearing off that Mix panel to make it a new window.
    So that works for monitoring but not (it seems) fro making sub clips with 1 or 2 tracks from the original 8.
    In Avid the selected tracks define the sub clip
