Activity Forums Adobe Premiere Pro How do you see program window on separate flat panel
  • How do you see program window on separate flat panel
    Posted by Mjsproductions on September 5, 2006 at 9:27 pm
    I have a ge force 7600gs graphics card and i’m trying to display program only
    on #2 monitor. How do you set this up??
    Steven L. gotz replied 20 years ago 3 Members · 2 Replies
  • Vince Becquiot
    September 5, 2006 at 10:35 pm
    Drag your program window to the second screen while it isn’t maximized. I believe it will stay the same way the next time you restart it.
    The only to have it maximize in the other window is to reverse the order of your primary and extended monitors.
    Vince
  • Steven L. gotz
    September 6, 2006 at 4:36 am
    If you tear off the monitor panel by pressing the Ctrl key while dragging it, you can put it anywhere you want.
    Steven
    https://www.stevengotz.com
