Activity Forums Adobe After Effects how do you replace a single layer?
  • how do you replace a single layer?
    Posted by Malcolm Desoto on July 20, 2007 at 8:50 pm
    I’m scanning the manual for this but haven’t found it yet. I know you can replace a layer in the project window (right click > Replace footage > File), but that won’t work in this instance. I built a 3D room in AE. Each wall is just a copy of one layer. If I replace that layer from the project window it will replace all the walls. I only want to replace one with out having to re-adjust all the attributes and line it up. Any ideas?
    rooom
    Aaron Ray replied 17 years, 6 months ago 4 Members · 4 Replies
  • Kevin Camp
    July 20, 2007 at 8:57 pm
    in the comp, select the layer you want to replace. then, hold ‘option’ on mac (alt? maybe on pc) and, from the project window, drag the new footage/image into the comp. that should replace that layer witht he new one and keep all the effects and parameters of the previous one.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Malcolm Desoto
    July 20, 2007 at 9:02 pm
    Excellent!
    Thank you very much kind sir.
  • Martha Castillo
    January 8, 2009 at 4:36 pm
    Just learning AE and this is a very helpful tip. Thx.
  • Aaron Ray
    March 11, 2009 at 10:16 pm
    I’ve been trying to figure this out forever! Thanks.
