Activity › Forums › Adobe After Effects › How do you remove transparency when using track mattes?
  • John Cuevas
    September 23, 2013 at 4:00 pm
    Is it the part with the giant “monster” like creature on the right? It seems the eyes are showing up, are they a different layer? Can you post a picture of your luma matte, please—that will help diagnosing the problem.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Luyi Yang
    September 24, 2013 at 1:37 am
    The eyes are on the same layer as the Zombie. The zombie itself is black and the eyes were white. I just made the track matte of the zombie to Luma Matte. Here’s a screenshot of it at the moment.
    https://i1248.photobucket.com/albums/hh485/looyee/LumaMattes_zpsbc4f91ae.jpg
  • John Cuevas
    September 24, 2013 at 11:29 am
    Luma mattes are based on the lightness/darkness of the layer above it. So if your zombie is black, it should be transparent, while the eyes being white, the paper texture is seen there. You can choose luma-inverted if you wish to flip the order.
    Thinkck.com
  • Luyi Yang
    September 24, 2013 at 11:50 am
    Yep the zombie itself is all black and the eyes are white. I’ve tried all the track mattes and the Luma Matte was the closest one to what I wanted it to look like, the problem is only the transparency bit.
    This is the zombie without any mattes applied. Only black and white:
    https://i1248.photobucket.com/albums/hh485/looyee/Zombie5_zpsc1036629.jpg
  • John Cuevas
    September 24, 2013 at 4:29 pm
    If you want the eyes to be different but also tectured, then you need to composite this as 2 layers, 1 for the eyes and 1 for the body. Because black won’t work as a luma matte. When you use black you are telling AE, to ignore this area, only use the white.
    Thinkck.com
  • Ashish Gupta
    October 1, 2013 at 12:47 pm
    Luyi Yang,
    Can’t really be sure without looking at your paper texture .. but my suggestion would be to use blending modes with the paper to merge it with zombie layer ….
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
  • Nick Shively
    May 16, 2017 at 4:15 pm
    I know this is an old thread but I came across it trying to find answers to the same problem and hopefully can help someone else in the future. Anything that is not absolute white or black in your matte will end up looking transparent. To solve this throw a “fast color corrector” on your matte and adjust the white and black input sliders to get your desired look.
