Activity › Forums › Adobe Premiere Pro › How do you output or export only a portion of a sequence?
Posted by Tim Mccarthy on June 22, 2007 at 7:39 pmI want to export part of a rather long sequence to see if my effects look okay in something other than PP2. How do I go about doing that? Thanks.
Pentti Kakkori replied 19 years, 3 months ago 5 Members · 10 Replies -
Maxsideburn
June 22, 2007 at 8:03 pmIt’s extremely simple. Took me a while to figure it out also.
See the little thing I circled, that’s called the Work Area Bar, just drag each of its ends to where you want your clip to start and to finish.
https://maxsideburn.1majorhost.com/demo.jpg
Then when you export look in the export settings for a drop down list that says “Range”. Drop it down and select “Work Area Bar”.
Steven L. gotz
June 22, 2007 at 8:20 pmChange the duration of the work area bar to cover what you want to export and then export just the work area instead of the sequence.
Steven
Pentti Kakkori
June 22, 2007 at 8:26 pmFirst set timeline’s Work Area Bar on your portion of a sequence
then
File>Export>Movie>Settings>Range:Work Area Bar
Tim Mccarthy
June 22, 2007 at 8:45 pmI can’t see your link, but it’s clear what your talking about. Thanks for your help.
Steven L. gotz
June 22, 2007 at 11:35 pmSearch the help file for the following and it will show you the work area bar:
“navigating in the timeline panel”
Steven
Mike Velte
June 23, 2007 at 10:51 amKeyboard short cut is Alt plus the left or right bracket[] will set the beginning or end of the bar to your CTI position.
Pentti Kakkori
June 23, 2007 at 4:59 pmWe who don’t use US keyboard don’t have these shortcuts. I tried to use Keyboard Customization Window, but I didn’t find the shortcut. Maybe I’m tired, is it there?
Steven L. gotz
June 23, 2007 at 5:12 pmIn English, the Keyboard Customization dialog has three sections. The default, I believe, is Application, then there is Windows, then tools.
In the Windows section under Timeline Window is:
Set Work Area Bar In Point and
Set Work Area Bar Out PointSteven
