Activity Forums Apple Final Cut Pro Legacy How do you move clips from an iMovie project into FinalCutExpress efficiently
  • How do you move clips from an iMovie project into FinalCutExpress efficiently
    Posted by Jeffreyb on May 27, 2006 at 5:57 pm
    [I’m still using FCE v1.01]
    If I use the iMovie “share” with best resolution, I get .dv files. When I import these files into FCE (using a drag from the finder onto the time line), I can view the cut, but any changes require re-rendering the audio.
    I “solved” this problem by rendering the audio in the clip and saving it as an FCE movie file and then re-importing that file.
    Needless to say, the above method is very inefficient for more than 5 clips.
    Is there a better way to import clips from iMovie. (The whole point of this exercise is so I can integrate clips from two cameras into the time line and not loose the previous editor’s work in iMovie.)
    Does anyone have any suggestions?
    Thank you
    A direct reply to jeffb@lmi.net is very much appreciated.
    Tom Wolsky replied 20 years, 3 months ago 3 Members · 4 Replies
  • Todd Gillespie
    June 1, 2006 at 4:10 am
    I believe the problem is that iMovie runs the audio at 32 khz, not 48 khz in FCE. I don’t believe that there is a way to get iMovie to export a 48 khz.
    You are using the same process that I would do if I had to change the settings. I’ve never use FCE, but if it has the ‘batch render’ then you could bulk render out the files.
    FWIW
    Todd at UCSB
    Television Production
  • Tom Wolsky
    June 1, 2006 at 11:50 am
    Sure. You can use the Share function and export to QuickTime. It’s the standard QT export module with all available QT functionality including third party encoders.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Jeffreyb
    June 2, 2006 at 2:24 pm
    Thank you gentlemen. Looks like there’s no quick and easy way to
    preserve the lines between iMovie clips and “Share->best quality Q-time them.
    I ended up sharing each clip as a .dv file, importing the .dv clip into FCE, rendering “Exporting” it as a Final cut (non-standalone) movie, and finally dragging that movie back into the time line.
    (Too labor intensive for my taste.
  • Tom Wolsky
    June 2, 2006 at 2:48 pm
    No, no, don’t use DV Stream, the .dv format. That’s the file format used by iMovie. If you’re going to FCE you should export to QuickTime make a .mov file using the DV codec.
    All the best,
    Tom
