Activity › Forums › Canon DSLR Cameras › How do you match lenses, if some lenses look sharper than others?
  • How do you match lenses, if some lenses look sharper than others?
    Posted by Ryan Elder on December 5, 2018 at 12:47 am
    Basically if I am doing a movie shoot where I want to use different lenses throughout a scene, how do I match the look, since they look different at least to me.
    I have Canon 24mm and 50mm prime, along with a 70-300mm zoom lens. The two primes look very much the same in terms of sharpness and quality, but the 70-300m has a softer look to it, and doesn’t look the same at all to me. But I do have a lot of shots, where a telephoto does come in handy.
    So is it me, or does this lens looks different than the others, and needs to be matched somehow, if anyone knows?
    Gary Huff replied 7 years, 9 months ago 3 Members · 13 Replies
  • 13 Replies
  • Warren Eig
    December 5, 2018 at 3:34 pm
    Yes, the lens will look different as they aren’t matched like more expensive cine lenses. The primes are sharper and also better quality with less glass. The zoom has more elements and not as high quality.
    You might try to add a sharpen to the zoom footage in the editing program you use, or create an overall look that hides the disparity. I like to shoot with black pro mists, ⅛ or ¼ depending, to soften the look over all as digital acquisition is overly sharp to me.
    You could also soften the primes to match the zoom.
    Warren Eig
    O 310-470-0905
    email: info@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    Vimeo: https://vimeo.com/babyboompictures
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Ryan Elder
    December 5, 2018 at 10:01 pm
    Okay thanks. For the future is there a good 300mm lens that can match the primes? There are ones that go over a thousand dollars but are their any that can match that are under a 1000?
  • Warren Eig
    December 6, 2018 at 7:48 pm
    You sort of get what you pay for. But remember, still lenses weren’t designed to shoot video, originally. Unless you buy a specific set of cine-lenses that are matched/calibrated, you just have to test and adjust your workflow accordingly.
    Warren Eig
    O 310-470-0905
  • Ryan Elder
    December 6, 2018 at 8:32 pm
    Okay thanks, but are you saying that since they weren’t designed for video, do you mean that the softer look they give is more acceptable in stills than video, is that what you are saying?
  • Warren Eig
    December 6, 2018 at 9:45 pm
    With today’s high resolution sensors, a softer look is actually desired. This is why I tend to shoot with an ⅛ or ¼ black pro mist filter in the matte box.
    Cine lenses are expensive and resolve a higher resolution.
    Warren Eig
    O 310-470-0905
  • Ryan Elder
    December 7, 2018 at 1:50 am
    Oh okay, I thought people actually thought the sharper, the better. So why are primes more popular then, if a softer look is preferred?
  • Warren Eig
    December 7, 2018 at 3:50 pm
    Primes are better because they are sharper. It’s easier to degrade or soften an image, either while shooting with a filter or in post, then it is to sharpen a soft lens.
    Warren Eig
    O 310-470-0905
  • Ryan Elder
    December 7, 2018 at 4:41 pm
    Do you think that shooting with a telephoto zoom zoomed in then would be riskier then since it’s quite softer looking?
  • Warren Eig
    December 9, 2018 at 5:20 pm
    If it is all you have and you know its limitations, use it sparingly if it looks very different from your other lenses.
    Warren Eig
    O 310-470-0905
  • Ryan Elder
    December 9, 2018 at 5:27 pm
    Okay thanks, I wasn’t planning on using a lot of shots with it, just a few for certain things, but I was afraid that maybe the sparing use will make it stick out like a sore thumb even more, but I did some tests. Sometimes I can see a difference in softness and sometimes I can’t and make it depends on how far away the actor is maybe?
