Activity › Forums › Apple Final Cut Pro Legacy › how do you like your apple/dell 20″ real estate?
  • how do you like your apple/dell 20″ real estate?
    Posted by Joslyn on June 13, 2005 at 4:39 am
    time to upgrade my HEAVY dual 21″ crt’s…was wondering how you’re liking the workspace of your apple or dell’s 20″ widescreen monitors? i wanna go w/ dual lcd’s and was thinking of going w/ dell’s widescreen 2005 20.1″ for the price. was also considering two of dell’s 2405 24″ monitors. was wondering if the 20″ers are big enough or go for the 24’s? thanks for you input!
    Graeme Nattress replied 21 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Graeme Nattress
    June 13, 2005 at 12:19 pm
    I’d go for at least a 23″ LCD. Two are nice, but at least one is superb, especiallly when dealing with any HD content as you’ve got more rez than the needed 1920×1080.
    Graeme
    – http://www.nattress.com – Film Effects for FCP
  • Mitchji
    June 13, 2005 at 6:58 pm
    A smaller second monitor works fine for me.
    Best Wishes,
    Mitch
  • Gunner Jones
    June 13, 2005 at 11:16 pm
    Caution: Those Dells are VERY bright, like they’ll burn a hole into you retinas bright, and there’s not an easy way to control them. Although in MacWorld Mag, I heard of a shareware utility that does this.
  • Mitchji
    June 14, 2005 at 1:02 am
    From another forum:
    Dell 2405FPW (24
  • Joslyn
    June 17, 2005 at 12:48 am
    wondering if anyone is running dual 23″ cinema displays? is it too big to work w/? thanks!
  • Graeme Nattress
    June 17, 2005 at 12:56 am
    I run dual 23″ displays and find it very useful, but I’m using one of them as a HD monitor: https://www.lafcpug.org/reviews/review_decklink.html
    Graeme
  • Joslyn
    June 17, 2005 at 5:30 am
    hey graeme, yes, i purchased 3 of dell’s 24″ monitors 2 for fcp and the 3rd i’m preparing for my hd preview monitor once the hvx comes out. i’ve never seen the dell in person so i’m wondering if this is too huge of a setup since i’m used to 20″ crt’s? also, is the decklink solution the cheapest route for monitoring dvcpro hd? thanks!
  • Graeme Nattress
    June 17, 2005 at 11:38 am
    It’s a higue setup allright, but should look awesome and there should be no limits to your productivity! The Deckllink card is the cheapest way to monitor HD on your FCP setup. However, I’ve heard that it’s a bit of a pain to get the Dell to monitor pixel for pixel over component, Adam Wilt had an article on his site about it, and just check that the component works good with HD because Mike Curtis at HDforIndies.com had issues with his in that mode.
    Graeme
  • Joslyn
    June 17, 2005 at 2:06 pm
    wouldn’t i be able to connect through the dell’s dvi port instead of component as in your decklink cinema display article? thanks again!
  • Graeme Nattress
    June 17, 2005 at 2:07 pm
    Yes indeed, but that’s an extra $695 for the magic box.
    Graeme
