Activity Forums Adobe Premiere Pro How do you export Proxy Files into a 4K movie?
  • How do you export Proxy Files into a 4K movie?
    Posted by Andrew Crittenden on November 3, 2018 at 1:50 pm
    Editing with premiere cc 2017.
    Imported 4k footage as proxies. But now file is set up to change 4k into proxy files when imported. So I am working only with proxies.
    Now I want to export into a fully rendered high res 4k file.
    Is this possible?
    If so, how?
    Andy
    Yair Bartal replied 7 years, 10 months ago 3 Members · 2 Replies
  • David Baud
    November 3, 2018 at 7:49 pm
    In Premiere CC 2018, if you have ingested proxy files associated with your original files, any time you export or render from your sequence, Premiere Pro will use the original file… so if you used the Premiere Pro feature you should be good to go… again in CC 2018… I don’t know when this feature was introduced…
    Otherwise, you could always manually reconnect your media to your original files and then do your export… just make your proxy files offline and reconnect with your original files…
    David Baud
    Colorist & Finishing Editor
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • Yair Bartal
    November 3, 2018 at 8:37 pm
    “I don’t know when this feature was introduced…”
    That is so since the very beginning of the proxy procedure in cc 2015.3.
