Activity › Forums › Adobe After Effects › How do you create shadowed corners?
  • How do you create shadowed corners?
    Posted by Chiara Sybesma on December 13, 2008 at 4:20 pm
    I’m relatively new to After Effects so I’d appreciate any helpful feed back with a problem I’m having. I want to creat the look of a light at the center of my project, with all the corners shadowed out. This video from youtube has the look I’m aiming for https://www.youtube.com/watch?v=GLMQt7CPWKk&feature=related . I’ve tried seting up a light in my comp but it won’t cast that sort of shadow in the corners of the background. Any ideas?
    Your help is GRATELY appreciated! Thanks guys.
    Kevin Fillie replied 17 years, 9 months ago 3 Members · 2 Replies
  • Brian Charles
    December 13, 2008 at 9:07 pm
    Do you mean a vignette? If so try adding a solid layer with a radial ramp on it with white at the center and black at the edges then composite using the multiply blend mode.
  • Kevin Fillie
    December 15, 2008 at 2:25 am
    Hey Chiara,
    You can also create a black solid, then with the pen tool create a circle. Make the circle fairly large (almost comp size) and change the mask setting from add to subtract. Hit the f key and increase the feather property until you get the desired look you are going for. Hope this helps. C U 2 Morrow. : )
