Activity › Forums › Apple Final Cut Pro Legacy › How do you convert an STL to an XML so i can use subs in FCP
  • How do you convert an STL to an XML so i can use subs in FCP
    Posted by Brandon Donnelly on October 1, 2008 at 3:57 pm
    I need to take an STL sub file and convert the document to an XML so i can shift the subs in FCP before i export them and authoring can be done. The reason i need to take the subs into FCP is because the subs came from a PAL DVD and now i have to realign them in FCP with my now NTSC video…
    I basically need a program like title change that will convert STL to a readable FCP stream like XML’s
    If anyone could help me it would be really appreciated.
    Andreas Kiel replied 17 years, 12 months ago 2 Members · 1 Reply
