Activity › Forums › Adobe Photoshop › How do you add Special characters with Photoshop text?
  • Richard Harrington
    July 30, 2006 at 3:25 pm
    Go to your System Preferences…
    Access International
    Go to input menu and turn on character palette… pretty easy from there. Document in Help
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Walter Vom saal
    May 8, 2009 at 4:23 pm
    Using Microsoft Vista and Photoshop CS2, the following procedure works for me.
    Go to All Programs > Accessories > System Tools > Character Map
    Select desired font, select desired character, click Select box at bottom, click Copy box at bottom.
    Return to Photoshop text box, insert cursor to desired location in text box, click on Window > Character to get the Character Palette, select the same font you used to get the character, select Paste (Ctrl+V).
    Caution: if you do not use the Character Palette to select the same font you used to choose the special character, you will get incorrect results. For example, choose an arrow character in Wingdings and paste it into a Photoshop Text Box, and if you have your font set to Times New Roman it will come out all wrong. Then use the Character Palette to change fonts from Wingdings to Wingdings2 to Wingdings3, and you will see how it changes.
