Activity Forums Avid Media Composer how do you add music to your edits?
  • how do you add music to your edits?
    Posted by Milton Hockman on January 13, 2007 at 7:28 pm
    hi,
    i would like to get everone’s take on their method of adding music to their edits.
    as i watch tv i notice that music is changed in order to transition to a new segment or topic of the video.
    when you are editing are you editing to the music choice that you made already for the scenes? or are you laying out a fully edited piece, and then go back and add in the different music tracks and tweaking your edits to that?
    what is the best process?
    Erik Pontius replied 19 years, 7 months ago 3 Members · 6 Replies
  • Michael Phillips
    January 13, 2007 at 11:50 pm
    Depends on the program type – for the most part, films, drama, and sitcoms do the edit first to meet story, time, etc. and the music is that added as needed to bring further enhance the story being told.
    Michael
    anything 24fps
  • Erik Pontius
    January 14, 2007 at 2:36 pm
    For other edits, like music videos, show openers, video montages, etc.. the music is most often the driving influence behind the edit, so it’s dropped in first and the edit is built around it.
    As was said earlier, in narratives, the story is king so the music is added, in most cases, afterwards to add some spice… In a lot of cases, composers are hired to write the music to suit the edit after it’s been locked.
    Erik
  • Milton Hockman
    January 16, 2007 at 3:22 pm
    what about for corporate video stuff or tv shows on the food network? or home and garden tv?
  • Erik Pontius
    January 17, 2007 at 6:52 am
    Corp stuff is usually pretty easy. Drop it in after your edit if you are using canned tracks…it’s generally used as a sound bed to bridge your soundbites together and make everything flow.
    I would assume that Home Garden/Food TV stuff, you’d do something similar, drop it in afterwards matching music to the theme of the episode. In corp/hg/food, the story is still king…you’re providing information to a viewer, they could probably care less about the music as long as it suits the scene and doesn’t interfere with what’s going on.
    Erik
  • Milton Hockman
    January 17, 2007 at 3:08 pm
    lots of times it seems like the edits are cut to the music on food tv. so maybe they do the music along side the edits?
  • Erik Pontius
    January 17, 2007 at 6:52 pm
    Could be. Tweaking your edit to match some key points in the music can help a bit with the flow. I like to hide some cuts by timing them around a beat. It’s also a good chance that network TV programs have their own in house composers.
    Erik
