Activity › Forums › Adobe Premiere Pro › How do you add a preset to the In panel effect drop down lists?
  • How do you add a preset to the In panel effect drop down lists?
    Posted by James Barnette on February 23, 2019 at 7:17 pm
    I’m adding effects to the track mixer and I have a ton that I need to add the same setting to. I know how to make presets but,
    How do I make a preset that appears in the preset dropdown for the effect?
    for instance. I’m using “Parametric EQ” it has a dropdown at the top of the panel for the EQ setting. I have made presets but they don’t appear in this list.
    they show up under presets in the effects presets window but only there. Wich makes the useless if I can’t apply them to the affect when it is in the audio track mixer.
    John Pale replied 7 years, 7 months ago 2 Members · 1 Reply
  • John Pale
    February 24, 2019 at 5:02 pm
    You can’t. Which is ridiculous and infuriating.
