Activity Forums Maxon Cinema 4D How do you add a light to a extruded text in c4d?
  • How do you add a light to a extruded text in c4d?
    Posted by Sanjeev Ramanathan on May 23, 2011 at 9:48 am
    How do you add a light to the text.?
    (Area shape: Object/spline)
    I need to get the text extruded and give light to it but the area light is taking only the spline and not the extruded text.
    If i drop the text in Extrube NURBS i can only add light to one side by adding Cap1 or Cap2 to the area shape. But i want the whole big bulky text to be light up.
    Is it possible?
    Bee.
    Sanjeev Ramanathan replied 15 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 23, 2011 at 3:52 pm
    You have to make the extrude nurbs editable and then use the connect function to fuse the sides and caps. Then drag the resulting object into the light’s Object box.
  • Sanjeev Ramanathan
    May 24, 2011 at 5:34 am
    Got it, appreciate your help.
    Bee.
