Activity Forums Maxon Cinema 4D How do we put a texture of annual rings on a stump?
  • How do we put a texture of annual rings on a stump?
    Posted by Serge Boucher on December 10, 2019 at 9:58 pm
    Hello,
    I tried different things: in the color channel of the material editor, I chose wood as a texture and then I checked the annual rings in the shader tab and tried to put it on the top of the stump but it doesn’t work no matter the type of projection I used. I tried different options of length and offset with the same result. It’s the same thing when I checked the legacy option instead of the annual rings option in the shader tab. I don’t know how to fix it. Help please.
    Thank you!
    Jim Scott replied 6 years, 9 months ago 2 Members · 3 Replies
  • Jim Scott
    December 11, 2019 at 12:24 am
    Hi Serge,
    In texture mode rotate the texture so that its Z axis is vertical. The axis of the rings is the Z axis of the texture, so in order for the rings to appear properly the Z axis of the texture needs to align with the Y axis of the stump.
    From the Help menu (If you’re not familiar with accessing the Help menu, rt. click on “Annual Rings” in the shader properties and select “Show Help”) :
    Annual Rings
    If enabled, the Wood shader will display growth rings that are arranged in concentric rings around the growth axis. This axis is the texture’s blue Z axis (main menu: Tools | Modes | Texture Axis. Move or rotate this axis if the growth rings should lie differently on the given object.
  • Serge Boucher
    December 11, 2019 at 12:47 am
    Thank you so much Jim, I didn’t know that.
  • Jim Scott
    December 11, 2019 at 1:04 am
    Glad to help.
