Activity › Forums › Adobe After Effects › How do they get rid of Track Points on Chroma?
  • How do they get rid of Track Points on Chroma?
    Posted by David Del on August 9, 2007 at 3:45 pm
    I have noticed in the BTS of DVD, there are cross-hairs and other types of track points (not in green or blue). How do they get rid of these – I assume they use them to track the background etc, but when they are on the greenscreen and they key it out – shouldn’t the track points still be there and therefore in the shot? Is this erased by keyframing like when they get rid of wires and cables from shots?
    Danny Princz replied 19 years, 1 month ago 6 Members · 5 Replies
  • Roland R. kahlenberg
    August 9, 2007 at 4:10 pm
    A second key on the dots would work well. If there are issues, there’s always good ole’ rotoscoping.
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • David Franklin
    August 9, 2007 at 5:02 pm
    A second key usually won’t work because it takes out portions of the subject with it (this is why chroma key screens aren’t white). So you have to draw garbage mattes around your foreground elements that keep the green around the subject but mask out the white reference points.
    However, even that doesn’t work when the subject crosses over one of those points.
    My solution in my own work when that happens has been the aforementioned “good old rotoscoping.” Any one have a better, faster, bolder solution?
  • Scott Roberts
    August 9, 2007 at 5:42 pm
    Aren’t those crosshair points used to track objects, for instance 3D generated graphics that overlay over video such as the characters Pirates 2? Is this the same thing you’re taking about? What DVD are you referring to?
  • John Dickinson
    August 9, 2007 at 7:51 pm
    Personally I always try to avoid rotoscoping whenever possible. Best case would be a rough holdout mask around the talent and a second pass key to remove the bulk of the markers. But you’d need some roto work where the talent passes in front of markers.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Danny Princz
    August 9, 2007 at 11:56 pm
    i agree with john.
    roto should not be necessary to remove most if not all your markers if its shot well.
    clean up when they cross behind an actor maybe necessary but a garbage matte and a 2nd key should do the trick
    Now if for some reason the above doesnt work, you could always do a quick track on the point and use that to remove the unwanted markers from key
    who is that masked man…
    https://www.exposedideas.com/
