Activity › Forums › Apple Final Cut Pro Legacy › How do I write out an AVI file in “Uncompressed RGB 24Bit” ?
  • How do I write out an AVI file in “Uncompressed RGB 24Bit” ?
    Posted by Rajnesh Domalpalli on July 9, 2009 at 1:29 am
    We just received specs requiring us to create:
    Video as an AVI file in “Uncompressed RGB 24 Bit”
    And Audio in “Uncompressed PCM 24Bit 48KHz”
    I have FCP 6.0.6, and I went to the Menu item under Export->Using QuickTime Conversion, and chose AVI.
    VIDEO
    Under Settings for Video, I chose:
    Compression type = None
    Frames per second = 23.98
    But I also see a section called Compressor (with options such as Thousands of Colors etc.) What should I set this to?
    Also, where do I specify RGB and 24 Bit?
    AUDIO
    Under Sound Settings, I chose:
    Compressor = None
    Rate = 48KHz
    Size = 16Bit
    Use = Stereo
    The question I have is: Is “Compressor = None” the same as PCM Uncompressed?
    Thanks in advance for your reply.
    Regards,
    Rajnesh
    Rajnesh Domalpalli replied 17 years, 2 months ago 2 Members · 2 Replies
  • Rafael Amador
    July 9, 2009 at 6:06 am
    Hi Rajnesh,
    The setting are OK.
    You need to export “Millions of Colors” unless you want to export an Alpha Channel.
    In that case you have to set it to “Millions+”.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Rajnesh Domalpalli
    July 9, 2009 at 6:45 pm
    Thank you… that was what I was searching for.
    Rajnesh
